There’s a pelican parts article about swapping the cluster with a 996 cluster. It is easy to follow. But after removing all the screws, pull it straight up to remove it from the clips holding it to the dash. Then remove the hazard light wiring. You might be able to reach the three connections without removing the hazard wires.
