Old 07-21-2023, 03:37 PM   #2
dghii
Given removing and replacing the relay 'fixed' your problem (for now) I'd be looking at cleaning the relay socket contacts with electronics contact cleaner. Also be aware that there are a few microswitches involved that can be an issue with top operation.....parking brake switch (bypass at relay to eliminate or test), switch at the top latch and a switch on the drivers side, behind seat and below roll bar.
All may be worth a look due to age. Parking brake switch is easiest to eliminate and see if it affects your issues.
