Old 07-16-2023, 10:17 AM   #3
elgyqc
elgyqc's Avatar
I would like to buy locally, Auto Zone and O'Reilly are US only and I find the NAPA site a PITA.
The Porsche spec is 4mm OD and 1mm ID, the OD is important because all the connections are made with the OD, i.e. the tube is a male connector. I have found some vacuum tubing on Amazon that is 4mm OD and a decent temperature range but it is 2mm ID, is the ID important?
https://www.amazon.ca/Mssoomm-Silicone-32-81ft-Flexible-Transfer/dp/B08GKN8GGR/ref=sr_1_34?crid=MW7J2J0S9MQD&keywords=1mm%2BID%2B4mm%2BOD%2Bvacuum%2Btube&qid=1689528397&sprefix=1mm%2Bid%2B4mm%2Bod%2Bvacuum%2Btube%2Caps% 2C120&sr=8-34&th=1
Grant
