Old 07-12-2023, 11:51 AM   #10
nuvolari
And the plot thickens....
This is the other side of cylinder #2, the same cylinder.
All of the other cylinders except for the 2 with the pistons at TDC are perfect with no problems whatsoever. The mark in the pics below is rough, so I'm assuming a gouge.
What's the cause? Is this a broken ring?
Argh, only one way to find out, unfortunately and expensively, so I guess I'm tearing the crankcase down and looking to find out if the piston is damaged and the condition of the rings.
Of course, my main question here is if I could use this block as is with the other parts replaced or if once scored, will it only continue to self destruct? And of course I can already guess the answer to that question but all opinions appreciated.
00 986S
86 944 Turbo
87 VW Scirocco 16v
87 Alfa Romeo Milano
77 Alfa Romeo Alfetta Sedan
nuvolari is offline   Reply With Quote
