Old 07-12-2023, 10:50 AM   #1
RL911
Clutch bleed procedure
Hi, going to bleed my clutch on my 04 for the first time. Have I got this procedure correct? I skipped jacking car and removing left rear wheel.
1. Fill motive power bleeder with fluid, attach to master brake cylinder and pump to 15-20 psi.
2. Depress clutch to the floor.
3. Open slave bleeder valve on top of trans and allow fluid to drain until air bubbles are gone.
4. Close bleeder valve
5. Release pressure by unscrewing top of motive power bleeder
6. Manually raise clutch pedal.
Am I missing anything?
I usually bleed the brakes with the dry method. Any trick to avoid making a mess when unscrewing power bleeder from MC?
Thx
RL911 is offline   Reply With Quote
