Thanks, I hadn't seen that particular diagram in my searching. It doesn't help that the names of the parts isn't consistent across all of the sources I've seen. I had the coke bottle sound but replacing the purge valve (tank venting valve in that diagram?) and the tank bleeder valve (Operative venting valve in that diagram?) seems to have resolved that. The purge valve was definitely bad, not sure if the tank bleeder valve was a waste of money and effort or not. The reed switch works and clicks valve 11 and/or 12 in that diagram. I'll have to locate the ORVR valve and see if that's opening with the reed switch or not.
