Old 11-11-2006, 06:29 AM   #139
delubozparts
Vendor
delubozparts's Avatar
Originally Posted by JP-s-in st. louis
Did the dimensions of the tubes stay the same? Can you make the pipes to a full 2 1/2"
Hello JP-s-in st.louis,
The Inlet Diameter of the Piping is 2" I had capability to make these in 2 1/2" but that will to too much unless you had Supercharger or Turbo set up for your Boxster. Also with 2 1/2" will required welding to install the exhaust. Thank you !
Che
delubozparts is offline   Reply With Quote
