Old 07-09-2023, 09:26 AM   #6
Jager
Jager's Avatar
Originally Posted by doclaw64 View Post
I have an 01 S and I wondering if it is a battery issue or alternator or.... issue. Basically, if I run errands in the Boxster when I get in the car and start it, it strains to start. It does start on the 1st try but... It does not happen when I start it for the first time of the day or when it has sat for a few hours. I have also charged the battery overnight and it took a full charge, but it still had issues starting after I did that. I think it is not the battery since it starts fine in the morning and maybe it is the alternator? Any suggestions?
TIA
How old is the battery?
Check the battery voltage without the motor running.
Check the battery voltage with the motor running.
Next time you start the car when it is warm, make sure the Air Conditioning is turned off before you turn the key... what happens?
Jäger
300K Mile Club
