Thread: Coolant leak
Old 07-09-2023, 05:06 AM   #2
tcoradeschi
Registered Member
Spitballing here.
Is that one of the condensate drains from the heater box? Do you smell coolant inside the car? If so, maybe you are looking at a failed heater core, or something of that nature?
If you can get a pressure tester on the system, so you can pressurize it without the engine running, maybe you could listen your way to the root cause.
Tom Coradeschi
03 Boxster
tcoradeschi is offline   Reply With Quote
