Old 07-08-2023, 07:26 AM   #14
Dallas_986
Originally Posted by rennpart View Post
Just reporting my findings.
I edited my post.
If you "tap" a 2 wire sensor on an original 4 wire DME/instrument cluster car the instrument cluster temps won't display properly (reads very low)- the additional 2 wires on the 4 wire sensor output different ohms for the dash gauge.
I ended up having to use the 4 wire sensor and run 2 new wires. One is a ground, and the other has to go to the black XR2 connector in the trunk. I ran the ground to the trunk as well and tapped into the original ground source just to be safe.
--Aaron
Aaron,
I’m working through this exact same issue on my car that I replaced the engine on. Could you provide some more detail on how you connected onto the 4 pin temp sensor, got the two “original” wires to the 2 pin connector on the engine harness, and where/how the two “added” wires connect into the XR2 connector?
I’m competent enough with nuts and bolts to do the engine swap but electrical stuff is outside of my knowledge base. Thanks!
Dallas_986 is offline   Reply With Quote
