Old 07-05-2023, 10:38 AM   #2
Homeoboxter
Originally Posted by doclaw64 View Post
I have an 01 S and I wondering if it is a battery issue or alternator or.... issue. Basically, if I run errands in the Boxster when I get in the car and start it, it strains to start. It does start on the 1st try but... It does not happen when I start it for the first time of the day or when it has sat for a few hours. I have also charged the battery overnight and it took a full charge, but it still had issues starting after I did that. I think it is not the battery since it starts fine in the morning and maybe it is the alternator? Any suggestions?
TIA
If the starter cranks the engine the same way at every attempt, I would suspect the CPS. When it fails, typically it does not work when the engine is hot and works fine when it cools down.
