Thread: Door Wiring
Old 07-02-2023, 11:45 AM   #2
elav
My car is currently in the body shop but when I get it back I will try and document the process of removing and installing this connector with pictures.
  • Disconnect the battery and wait the appropriate time to make sure the airbag system isn't charged
  • Remove the torx bit at the bottom of the connector (you may need to remove the arm that limits how far the door will swing in order to get better access)
  • Slide the connector up to remove
  • Installation is simply the reverse order
My guess is this is why my door speaker on this side isn't working, but will soon find out.
'98 Boxster 986
'87 911 Carrera Cabriolet
elav is online now   Reply With Quote
