Old 07-02-2023, 11:22 AM   #1
78F350
Motorist & Coffee Drinker
78F350's Avatar
Welcome to the forum. The most common coolant leak is at the tank in the trunk. Most of them have reached an age where they need to be replaced due to cracks. The cap on the coolant tank and the bleed valve on the tank are also common failures. Also if you don't know when the water pump was last replaced, it's s good idea to do it soon.
