Old 06-29-2023, 12:39 PM   #4
986Pcar
Originally Posted by tcoradeschi View Post
First things first. How did you adjust the cables? Does the green adjustment “tool” work with the short shifter? What happens if you go back to the original shifter? Time to reduce the number of variables…
You were right, reducing the number of variables is what did the trick. One of the actuating brackets on the outside of the transmission (where the cables attach) was very slightly bent. Probably from when I was yanking the old cables off. Once it was pushed back into place and the cables were properly adjusted, reverse was reachable. The car feels great now!
986Pcar is offline   Reply With Quote
