Old 06-28-2023, 07:07 PM   #2
Gilles
any cross-reference for 986S brake pads?
back story - i also race a 1968 triumph gt6. if you search pads for a triumph gt6 all you can find are crappy oem pads and crappy ebc pads. however the gt6 uses girling 4-pot calipers that were used on a lot of other cars of the era and if you search you can find lots of say cortina or lotus performance pads that work on the gt6.
so, given the 986 uses standard brembos, are there other cars that run the same calipers with pads that don't include the porsche tax? i'd love to find a set of pagid yellows for say a jetta that didn't cost $700/axle ...
Radium, I have a used set of Pagid Yellows that I used for one season with the POC on my 987 CS, I believe that the caliper sizes are different between the S and the Base Models.
They are a bit discolored but can measure them (for wear) if you are interested, as I cannot use them on the 981CS as the rear calipers are different size as the ones on the 987CS.
I can take a picture of the original Pagid boxes so you can check if these P/N's will fit your 986S, thanks!
