Old 06-28-2023, 06:03 PM   #6
KevinH1990
KevinH1990's Avatar
If you are sure that the headlights are seating properly (it can be surprisingly difficult to make them connect) it is possible that the switch has failed. Before you work on the switch, I recommend that you verify that nothing is working on the light assembly. To do this, check to see whether the turn signals/emergency flashers and fog lights are working. Also check if the rear lights turn on when you switch on the headlights. If nothing is working in the front and the rear lights turn on, I think you should focus on making sure the headlight assemblies are connecting correctly.
Also, if you have litronic headlights, there are two sets of connectors that you need to check.
That said, the light switch is not an uncommon failure item. When mine stopped working, I removed it and soaked it with electrical contact cleaner. That restored it to full operation.
Good luck.
