Old 06-26-2023, 09:10 PM   #1
Escott1622
Non confirmed missifire at idle
2001 986 2.7 80k miles. Randomly starting this morning when I started the car I got a slight rough idle with no CEL. Car revs up and even drives and feels like it has most of it power but once you are at idle it sounds exactly like the car has an aggressive cam. I did replace the AOS 10-20k miles ago and only get white smoke maybe once every few weeks when the car sits for awhile. Is there any like big things that normally cause this I should check? I’m used to engine codes. I do have a smoke machine I can use but can’t get to the car till next week. My lift is occupied so I figured I’d use the next week to see what you guys think, will probably replace AOS while I’m in there because of the white smoke. New spark plugs and several coils in the past 10k miles. I’ve normally always had check engine lights to diagnose so this is a first for me with this car not getting one
Escott1622 is offline   Reply With Quote
