Thread: water tank
Old 06-24-2023, 02:26 PM   #10
78F350
Motorist & Coffee Drinker
78F350's Avatar
Originally Posted by Apache1 View Post
... something hit the undercarriage in front and inside left rear tire causing a marble size hole draining my coolant fluid quickly. ...
From the front to the inside of the left rear tire is a broad range. Where is the marble size hole? Is that where the coolant appeared to come from? Can you post a picture showing damage?
The coolant tank is in the right rear of the trunk. Hoses and metal tubes lead from the front of the engine to radiators, passing along the inside edge of the front wheel wells.
