Old 06-24-2023, 08:18 AM   #1
jaimster
That is a lean alarm code. Double check the AOS connections, those are a pain to remove and reconnect. You need to hear or feel the click when reinstalling.
hum ! I did replaced the AIR OILSEPARATOR a while back did not have those code till I messed with it looking for the ECTS .. I just swapped back the old MAF sensor (bosh oem ) removed new one i had bought from rockauto .. wondering if that is the issue same BOSH numbers thought !!
sorry I should have mentioned I did replaced the MAF sensor few months ago when I was having issues thinking that was the issue turned out to be the ECTS
i started it . actually sounds pretty damm good . dont hear any hissing . pulled the codes afterwards NO CODES at all
maybe that was the issue ..
jaimster is offline   Reply With Quote
