Old 06-19-2023, 06:40 PM   #12
rennpart
Just reporting my findings.
I edited my post.
If you "tap" a 2 wire sensor on an original 4 wire DME/instrument cluster car the instrument cluster temps won't display properly (reads very low)- the additional 2 wires on the 4 wire sensor output different ohms for the dash gauge.
I ended up having to use the 4 wire sensor and run 2 new wires. One is a ground, and the other has to go to the black XR2 connector in the trunk. I ran the ground to the trunk as well and tapped into the original ground source just to be safe.
--Aaron
rennpart is offline   Reply With Quote
