Thread: 3000 rpm
Old 06-16-2023, 12:30 PM   #18
JFP in PA
Originally Posted by Uwe View Post
My 2000 S has the same issue, very faint on acceleration and cruising, sometimes not noticeable, but very pronounced while decelerating when the rpm's swipe through the 3000+- range.
Ive got nothing productive to add, other than seems to be a more common problem than I thought. The engine in my car has been replaced during prior ownership, with a 2002 S-engine. Maybe they didnt do the flywheel at that time. Receipts show clutch components, but no flywheel.
Are there visible clues if a dual mass flywheel has gone past it's lifespan?
No, unless is is really beat up. The correct way to test dual mass flywheels is to use the twist recovery method outlined in a factory TSB.
