Old 06-11-2023, 03:50 AM   #1
Starter986
1998 Boxster Silver/Red
Originally Posted by elav View Post
Hello! I have a '98 986 Boxster that was backed into nearly 5 months ago. I brought it to a body shop that has a good reputation and they replaced the passenger side radiator (mounting clip was damaged), fixed the front quarter panel, front bumper, etc. I decided to have the entire car painted while it was in there and just picked up the car after 5 months. The final bill shows a new radiator and coolant.
Driving the car home, the coolant light started flashing and I noticed the coolant was a bit below the min line. The car is way over due to be smogged and because the shop disconnected the battery, I needed to drive it 40 - 50 miles to get the sensors registering before smogging it. I did so and while it was being smogged it started leaking coolant from in front of the rear wheel on the passenger side (US car). Needless to say the smog tech was not happy that the rollers on the machine was covered in coolant.
Further investigation shows that there is moisture at the top of the rear trunk lid and a the top where the cap is was wet. My guess is the body shop had no idea that there is the bleeder valve under the cover in the coolant/oil AOS. What are the thoughts that this was caused by them not removing air in the system vs. something more? Should I simply fill it up with the vent open, warm it up, etc. to purge the air or should I check something else out first?
I should mention that the cap has already been updated to the -04 model
That.
1998 Porsche Boxster
