Old 06-08-2023, 04:19 PM   #37
78F350
Motorist & Coffee Drinker
78F350's Avatar
Originally Posted by Radman View Post
Definitely the WP. It was a pump with a plastic impeller so unfortunately who knows what went where. All of the vanes were impacted and all but two were almost completely gone. In addition, the pump had a fair amount of resistance when turning by hand. Resting up and will tackle reassembly in a little bit.
I know that JFP in PA has posted in a couple threads about how to flush the engine to get any residual pieces out. It is possible for them to block coolant passages and create problems if they remain.
Note for reassembly: The two bolts that are longer go in the holes with the dowel pins. Use a coated metal gasket (probably included) and no sealant. Torque 10 nm/7 ftlbs
