Old 06-06-2023, 12:53 PM   #20
78F350
Motorist & Coffee Drinker
78F350's Avatar
Call Pelican and confirm if the circlip is included in their IMS bearing kit. I'm pretty sure it is. It's been a long time, but I installed two in cars, both of which had come with a dual row bearing originally. The kit will also have an improved center bolt and seal.
Do NOT reuse an old center bolt after you have extracted a bearing with it. They are weakened and are more likely to fail than your bearing was in the first place. (I think JFP and J. Raby advised that a few times in years past).
I think I still have one more slightly used center bolt laying around if you want it. (BUY THE PELICAN KIT!)
Not sure if it's mentioned in videos, but when Burner did his years ago he got a slightly used center bolt from me. Hopefully it's all still good.
