Old 06-03-2023, 11:22 PM   #12
Bush Pilot
I’m addition, I believe that the ceramic pads don’t absorb heat as well as the OEM pads which results in higher temperatures of the disc and will result in a warped disc. The brakes are a system designed to work together and installing ceramic pads is changing the design with unknown results.
Bush Pilot is offline   Reply With Quote
