Old 06-01-2023, 07:48 AM   #2
blue62
Originally Posted by solo118 View Post
Thanks all. I need to set up a time to get it, and hopefully all will be well. Current owner says no leaks of any kind, but is there a way to check from under the car if the pump has any weeping? I think also I checked the coolant tank in the past, but I could be thinking of something else.
Thank you also to Hasdrubal- I believe I have AAA as well, so heaven forbid anything was to happen I just have to make it 100 miles from my home
If your worried about any type of issue with the coolant system take a coolant pressure tester kit with you when you pick up the car.
Test the coolant system. If the coolant system holds pressure under proper test conditions Then there are no leaks in the system.
