			Update: I swapped out the shift linkage today and the problem is the same as before. I also tried getting some more (gentle) leverage on the short shifter: to no avail, so I can confirm that is not the issue. Cable seems to be actuating properly (it moves but the column going into the transmission does not). I can still get into reverse by moving the pieces on the transmission end by hand but not by cable.
