Old 05-28-2023, 04:30 AM   #5
Kice
[QUOTE=JBauer;653466]
Originally Posted by Kice View Post
Those LED strips are held on by double sided tape. Looks like they are stuck to the inner bexel. It's hard plastic. He added a cheap projector, might have ruined the bowl doing it. This isn't hard to fix if you are a little handy. You can make a cardboard box oven with a box and a heat gun. Depending on how he resealed them. Those are worth fixing. If yo think you can do it, he didn't cut up the wires, I have all the parts to make them back to stock, I sell what you need and won't hold you up.. First post a pic of the back open showing the wiring. Also do they work now?
They work but the wiring is a complete nightmare, all cut and taped - the cable harness is totally messed up. Will try to warm them up as you describe and then see if i can pry off the cover glass. Looking at the seam of the glass cover I get the impression liquid nails were used...
Kice is offline   Reply With Quote
