Blocked Reverse Gear 5 speed
Just upgraded shifter cables to numeric. I did not replace the shift linkage though it looks ever so slightly bent. I also installed a short shifter while I was at it. After installing I have all 5 “forward” gears but it feels as though there is a wall blocking reverse. If I reach up to the transmission I can push the linkage with my hand so that it goes into reverse with about the same resistance as any other gear. Nothing is blocking the shifter itself either. I might try popping the cables back off and adjusting them again, but any other ideas? Could the cable be getting stuck on something somehow? I find it odd that I can reach both 5th and 2nd from within the cabin but not reverse (ie seem to have the vertical and horizontal range). I’m a bit lost on this one. I even started the car and no weird grinding noises or funny feelings while shifting -reverse is simply blocked no matter how hard I try to force it.
