Old 05-24-2023, 11:05 AM   #11
nuvolari
The dual row bearing requires quite a bit of force to get extracted. The pulling force needs to be perfectly lining up with the shaft, or else it will get stuck. Your setup seems a little off to me, make sure the collar sits on the shaft evenly and everything is perfectly centralized. And find something better than that washer, I don`t think that can be aligned too well.
Yup, I think you're right. Also, the pilot bearing puller tends to go off center which doesn't help and tends to pull the sleeve and the bearing slightly less than perfectly straight.
00 986S
86 944 Turbo
87 VW Scirocco 16v
87 Alfa Romeo Milano
77 Alfa Romeo Alfetta Sedan
nuvolari is offline   Reply With Quote
