Old 05-24-2023, 08:22 AM   #315
The Radium King
The Radium King's Avatar
not sure if there was an 's' version of the 996 (at least in 2000 anyways). regardless, all 996 used the same tune.
the 997 (or 996) intake plenum (the 'tee') will fit on the boxster 3.2 intake. it is the same width but a slightly larger diameter - i was able to stretch the rubber boots to fit no problem.
what bends, etc. you use would depend on whether you are using the 986 or the 987 maf housing.
if you are going with the 986 unit i've got the assembly off my car i could probably part with (ie, when i did the airbox and tb/plenum but hadn't done the tune yet).
