Old 05-16-2023, 08:49 PM   #17
professorman
Originally Posted by irogag View Post
Yes just turn PCB over and you will find the pins below the relay. For example (check my work here, as I didn't see A108) but on the 5pin relay in this dataheet :
Mini Relay K (Open – Sealed) Automotive Relays PCB Relays https://www.electrokit.com/uploads/productfile/41019/V23072.pdf
You would set power supply output to 12V and apply positive to 1 and negative to 2 ( if it's not marked as - and +, polarity is indifferent). Test ohms across 4 to 7 for N. O. AND 4 to 5 for the other N. O. I am basing all this off the 1 Form U/X, 2 No diagram. So if yours if different adjust accordingly
Thank you. Do you know how I can purchase new relays? What numbers should I look for?
Do you have any sites that you use?
01 Boxster S 6Spd, Speed Yellow w/84k miles. | 991.1 911 C2 7spd Manual | 01 996 C2 -6spd - Green Machine - My baby | 997.2 C2S 6spd | 2x 01 Boxster base
professorman is offline   Reply With Quote
