Originally Posted by professorman
Can you elaborate on how to test the relays? Do I test them from the underside?
Eg. One of my relays are: V23072-C1061-A108 ++ 24311
Yes just turn PCB over and you will find the pins below the relay. For example (check my work here, as I didn't see A108) but on the 5pin relay in this dataheet :
Mini Relay K (Open – Sealed) Automotive Relays PCB Relays https://www.electrokit.com/uploads/productfile/41019/V23072.pdf
You would set power supply output to 12V and apply positive to 1 and negative to 2 ( if it's not marked as - and +, polarity is indifferent). Test ohms across 4 to 7 for N. O. AND 4 to 5 for the other N. O. I am basing all this off the 1 Form U/X, 2 No diagram. So if yours if different adjust accordingly
