Old 05-09-2023, 04:24 PM   #20
gtsracer
Originally Posted by seningen View Post
Racer thing -- not on a street car.
Since you have a voltmeter -- start measuring voltages at different places around the car -- find an online wiring diagram to find the locations you should have 12v.
Especially check the connector at the front/top of the engine compartment. It sort of a jumped box from the engine area to the front of the car (and your battery). It's a simple post with a 10 or 13mm nut that could have worked its way loose.
There is also the fuse box behind/under the dash/glovebox (if you have one) that connects to the battery and has some master fuses there.
Mike
Will check some more. Did check 80 amp fuses, seems fine.
gtsracer is offline   Reply With Quote
