Old 05-09-2023, 10:37 AM   #16
Gilles
Originally Posted by seningen View Post
There is also the fuse box behind/under the dash/glovebox (if you have one) that connects to the battery and has some master fuses there.
This fuse box has a rod that goes through the firewall and plugs with the + battery cable (with a funky connector), this is where the failure occurred on my 987.. just giggle the cable (at this connector) with the ignition on, to see if you regain power.
