Old 05-05-2023, 07:23 PM   #4
elgyqc
elgyqc's Avatar
ask yourself if maf readings matter. if trims are good and 02 sensor is working then maf readings must be ok, hey?...
I'm not going to be asking my self anything for awhile since I don't know much about all this!
Hopefully with help from you guys I will get a handle on it.
My low power problem is a lack of low end torque... and I know there is a problem because at the moment my 2000 Boxster S has (temporarily) a 2,7l engine in it (actually it has the original engine from this car) and it has a lot more torque at low revs, a LOT more. This one only starts to come alive as the revs go up.
Thanks for the clarification on the MAF.
I will check the knock sensors in my next test.
Grant
