Old 05-04-2023, 09:57 AM   #2
The Radium King
The Radium King's Avatar
your deviations seem typical - i ran there for a long time. your engine codes at 9 iirc.
your fra (load) numbers look excellent - can read anywhere between 0.7 and 1.32 before you code so .99 is about as good as it gets.
your rkat (idle) numbers appear ok as well - they are a % (as opposed to fra which is a discrete value) so .61% trim is good. (you can swing between +/-4 before code)..
however, was battery disconnected recently? it takes a while for long-term trims to reestablish themselves.
