Old 05-03-2023, 04:39 PM   #10
gtsracer
Originally Posted by seningen View Post
Take the battery out -- connect a charger to the car -- do you get things to wake up?
Sometimes a battery will fail internally and short things out -- even to the extent you can't jump it.
Also check the negative terminal and negative connection from the battery to the chassis.
I would also look for voltage at various points around the car.
Will check. Thanks
Tried but without success.
I ordered voltage regulator from FCP ($40 with shipping) will try it.
gtsracer is offline   Reply With Quote
