I have found a few other posts from you on this subject. So, it looks like you have been down this road. and maybe got smart and turned back.
This SC kit is for the 2.5 and I am thinking on putting this on a 3.2. The only issue is of course the exhaust.
I am looking at the left side of the engine, If I remove the airbox and mount the SC up high, this will allow a cooler location and less heat soak. The intake would be right there and allow cooler airflow.
Also, I would be able to follow the same path from the SC exhaust (boost side) that the original intake was using. I am many months away from attempting this project, so any input, suggestions and ideas are appreciated.
