Race, your ultimate power output will depend on several factors. Using bw's calculator, the 2.7 will put out 300hp on a tt setup at 5-6 pounds of boost (theoretically) and have a flat torque curve from 2000 rpm up (depending on exact setup) You sc setup will likely be less of a gain but it will definitely be a real one.
Your issue will be controlling boost. All low pressure systems must be insanely precise. This is far easier of a task to accomplish with a turbo rather than super setup.
Your install should be fairly straightforward if you're familiar with FI systems. Don't forget to swap your spark plugs though - commonly overlooked in builds.
Sent from my SM-N975U using Tapatalk
