Old 04-26-2023, 01:16 PM   #1
redpepperracing
Did the 'poor man' OBC mod, cluster lights stay on
Hello all,
I'm not sure what I did wrong here, but I did the 'poor man' OBC mod as described in the 101 projects, I used the proper wire connectors for the cluster plug, and inserted them in the proper positions, and after doing that, all of my cluster lights stay on, although slightly dimmer than normal. If I take off the parking brake I can see the light gets a bit dimmer, but still stays on, same for the ABS, brake pads, check engine, battery, wing, etc. I have even tried unplugging the switches, and it still does it. It seems like there is something grounded that shouldn't be, but I can't seem to trace it down.
When I had the cluster out I tried to swap in LED bulbs, but they didn't work at all so I swapped in all new bulbs, and still no change. I know for sure that prior to doing the mod there were no lights on and they were working properly, so it's obviously something I've done, I just can't figure out what. My next test is to try removing the new pinned wires from the cluster harness and see if that changes anything, but if anyone has any ideas, I'm all ears.
redpepperracing is offline   Reply With Quote
