Old 04-24-2023, 11:35 AM   #11
dsallean
Originally Posted by jstoddard View Post
dsallean - sorry, I realize this is an old thread. I'm going through a similar rewiring process now with my litronics. Other than the TE pins listed, did you replace any of the other pins and connectors or did you simply reuse them? If you replaced any of the other pins/connectors is there any chance you still have the part numbers?
Thanks,
Jeff
I did buy some of the other connectors, and reused some as it wasn't too difficult to remove the old wiring. I will go look and see if I have any other part numbers.
I did see recently that someone sells a wiring kit to replace the internal wiring in the headlights. That wasn't available, or at least I wasn't able to find it at the time I did mine. Honestly not a hard job once you get the headlights open.
I would post a link to the headlight wiring but it would get removed by the admin anyway. A search on the web for the internal headlight wiring harness will get you there.
Dave
dsallean is offline   Reply With Quote
