Old 04-23-2023, 02:33 PM   #10
LoneWolfGal
LoneWolfGal's Avatar
If the hard starting issue only arises after fueling up ......it is most likely an issue with something in the EVAP system. Like a faulty purge valve or cracked vacuum canister or the like.
If you had an issue with a vacuum line to the fuel pressure regulator I would think your hard starting issue would happen more often then just at fuel up.
When you have the hard start issue does holding the gas pedal to the floor help in getting the car to start?
It's hard starting only after fueling, no other time. Yes, flooring the gas pedal does help to get it running.
LoneWolfGal is offline   Reply With Quote
