Old 04-23-2023, 12:35 PM   #1
blue62
Originally Posted by LoneWolfGal View Post
Would you happen to have a photo or illustration that shows the location of the vacuum hose?
If the hard starting issue only arises after fueling up ......it is most likely an issue with something in the EVAP system. Like a faulty purge valve or cracked vacuum canister or the like.
If you had an issue with a vacuum line to the fuel pressure regulator I would think your hard starting issue would happen more often then just at fuel up.
When you have the hard start issue does holding the gas pedal to the floor help in getting the car to start?
