Ironically I had this exact same problem earlier today and I tried to post about it the performance and technical sub forum because it seemed like the right place to post it, but maybe it wasn't because my post never showed up.
My problem was I would stick the key in, turn it to on, the dash would light up, the vent blower would come on, the oil level check would do its thing, everything normal, but when I turned it to start everything went dead, completely dead, everything, dead.
I decided to check every fuse one by one, but thought maybe it would be a good idea to unhook the battery first. The second I touched the negative terminal I heard a click and everything was back to normal. Although my battery terminal was not corroded, looked perfectly tight, and even seemed tight with a gentle wiggle, when I really gave it a good wiggle it moved quite easily.
I took it off, cleaned it for good measure, put it back on and gave it a couple extra ugga duggas and everything is working perfectly now. So even if your terminals look clean and tight, I'd recommend taking them off, cleaning them, and putting them back on like the German engineers originally intended... Guten Tight.
