For the 986.1, maybe 986.2 is same?, the Xenon is a mono-Xenon and the high beam bulb is an incandescent bulb below the projector. If you have retrofitted these projectors and they have a shutter for bi-xenon function, you will need to run the 12v+ wire for that to the shutter motor inside the headlight.
Sent from my SM-G781W using Tapatalk
