Thread: Radio removal
Old 11-10-2006, 03:26 AM   #1
Chills
Send a message via Yahoo to Chills
Originally Posted by steve00s
You may have to pull fairly hard to get it to start moving. It can be kind of hard on your fingers. After you insert the keys in the slots, I have found it easier to use a screwdriver or some other small bar in the hoop of the key. Make sure you grasp the screwdriver or bar between your index and middle fingers with key in the middle. Pull with even force and it should come out.
+1 on this one. I thought I put the keys in wrong because I couldn't get the radio to budge. It was in there tight! I got a couple of pliers and slowly pulled on the keys. The screwdriver idea is much better. I wish I would have thought of that.
I bleed green
It's not about the summit, it's about the climb.
http://i133.photobucket.com/albums/q46/chills1138/2.jpg
Chills is offline   Reply With Quote
