Old 04-16-2023, 06:48 PM   #5
ike84
Originally Posted by Morph_986 View Post
Just goes that you need to check everything you learn. The device was called a sensor by the tech, the part description is sensor and the reason for the discussion involved small changes in oil pressure, not binary oil pressure or not.
If it is a switch, then I stand corrected.
Philip
Fun fact - that switch doesn't close (activate) until the oil pressure drops to 7 psi. Pretty worthless, if you ask me, considering the working pressures are 40-60psi. By the time that light goes off in a race, your engine is already toast.
Sent from my SM-N975U using Tapatalk
