Old 04-16-2023, 02:34 PM   #1
tspangle
FS: 2001 Boxster S manual in Michigan
2001 Porsche Boxster S. 6-speed manual, rare Rain Forest Green metallic paint with black leather interior. Bi-Xenon headlights and Sport package. Newer OEM top with glass window. Clutch, IMS, RMS, and AOS all replaced in 2021. 109k miles. Clean title and Carfax. New tires with less than 1k miles. Extensive maintenance done in the past 3 years, including:
* Pelican Parts IMS bearing replacement
* Porsche rear main seal
* URO Air-oil separator
* Sachs clutch kit with new slave cylinder and release bearing
* LUK flywheel with new Porsche bolts
* Transmission replaced with good used unit (still have the original if you want it)
* LN Engineering magnetic drain plug
* LN Engineering spin-on oil filter adaptor
* Bosch oxygen sensors (all 4 replaced)
* Denso platinum spark plugs
* Continental ExtremeContact Sport tires
* FAG rear wheel bearings
* Duralast Gold CV axles with lifetime warranty
* URO rear lower control arm
* Duralast Gold battery
* Mahle engine air filter
* Mann cabin air filter
* Continental serpentine belt
* OIl change with Mobil 1 0w40 full synthetic oil and Bosch oil filter
* Brake fluid flush with Valvoline Synpower
* Transmission fluid flush with Porsche fluid
* Porsche coolant expansion tank cap
* Walker cam position sensor
* Porsche fuel cap
* Removed intake snorkel (still have it)
* Lloyd Mats floor mats with green trim (still have OEM mats, but they are quite worn)
* Kenwood Carplay/Android Auto head unit (still have OEM CD220 unit)
All work done by myself following the factory manual. I have receipts for all the parts. Some LEDs are burned out on the HVAC display. It has a CEL for a P1325 code. I have checked the cam deviation and it’s within spec. I have not done further investigation and have priced the car accordingly. Also has a minor transmission fluid leak. Includes factory service manual and the “101 Projects” book. AutoCheck (similar to Carfax) report from when I bought the car in 2020 is available, as is the factory build sheet. VIN: WP0CB29821U662586.
Asking $11.5k. No trades, cash only please. Car is located in Brighton, MI.
Photo album: https://photos.app.goo.gl/HsKFVRxF588KYX2P9
tspangle is offline   Reply With Quote
