Old 04-16-2023, 08:17 AM   #17
JFP in PA
If the actuator needs replacement the part alone is around $1000, plus typically they pull the engine for the job (although it`s doable without doing that). This is the Bay area, so I wouldn`t be surprised if it cost around 7k. What would it cost to replace the actuator in your shop? Just wondering. For the Poster perhaps it`s worth a trip to PA
It isn't always necessary to drop the engine to do one of these actuators. Realistically, it should probably come in as a $2500 - $3000 job IF the actuator needs to be replaced, which is not always the case. More commonly, this is a wiring issue, which is why the OBD II manual describes it in the manner noted.
